Hi Sebastian,
I will need to confer with the dev team on this. If it is not a feature at the moment, I will see if it can be added to the list.
Aaron
Sent: 09-13-2023 06:30
Subject: Output FC in UHDp25 // Carbonite Ultra
Thanks for clearing that up Aaron,
I understand now. I had read that wrong...it makes sense on the chart.
Is there any reason that it is not supported or is it just not a feature at the moment ? i can understand that a conversion outside of the switchers native format would be a strech, but converting to 1080p25 would be nice in case you have to include some devices under 6G or 12G SDI capabillity.
Sebastian Kaiser
Operator AV
Sent: 09-12-2023 23:34
Hi Sebastian,
At UHDTV1 25Hz, the switcher supports input format conversion, but not output format conversion. I have attached a screenshot from the manual where it lists the supported FSFC Input and Output Formats at UHDTV1.
The switcher will need to be at 50Hz to convert the output to 720p/1080i/1080p.
Aaron
