I haven't thought of a possible solution yet but I would not even try and do this with a scene based script. Making the scene change its own framebuffer during any part of the prepare or beforeonline or runtime phase will definitely case instability and lockups.
If there is a solution its going to have to be modifying the take items before they go online, or using the play command itself to change the layer.
Sent: 07-19-2023 17:30
Subject: Override sequencer take item layer
Hey James, we have a fully automated workflow using a custom software that lives on each Xpression machine and talks to it through the COM API, so unfortunately a Dashboard situation wouldn't work in this case. Thanks though.
Sean Henry
Sent: 07-19-2023 15:31
Hey Sean,
What are you using to trigger scenes remotely?
In DashBoard, I have been able to reassign output layer for a specific takeID.
I didn't make it change generically, but the approach might come close.
James.
James Hessler
WAAY TV (ALLEN MEDIA BROADCASTING)
Sent: 07-18-2023 09:26
Thanks Red. Yes, unfortunately that is precisely the problem. Our app is explicitly setting the layer in the xml, so that's what I'm trying to overcome, at least on a temporary basis. The obvious fix is to remove that from the generated XML, but that app itself is a fully featured cloud-based platform, so it requires time from one of our dev teams and unfortunately they most likely won't have time to work on it for some time. I'm basically just looking for a workaround until that change can be made.
To your previous question, ideally I'm looking for something that can be put into an OnBeforeOnline script of a particular scene that modifies the layer before it gets to the framebuffer.
Sean Henry
Sent: 07-18-2023 05:41
I just went to look at how the xml's are formatted and there is something called "targetlayer" could you use that in you app?
Here's an example line;
<template name="Soccer GIP" scenename="Soccer GIP" projectname="example_1.42" targetid="10062" groupid="1" targetfb="1" targetlayer="0" targetsvrchannel="0" tcstart="00:00:00.00" tcstop="00:00:00.00">
Sent: 07-18-2023 05:38
Is your app setting the layer to be 1? I am sure if you set no layer in the XML it will take whatever the default for the scene is set within layout.
You can move items between layers using scripting, depends how you want to do it, would it be a script you want to trigger or something you'd want to build into the online of the scene to move automatically?
I would check first that the scenes don't just take their default layers, seems odd to me that they would be forced to layer 1, perhaps the app is doing that?
