Sent: 10-22-2024 07:04
Subject: Paging Like Data Shift to next Table
Thnaks. that works. rest is now up to the designer and loop things... You are the Man.....
[Wajahat] [Ali]
[Team Lead] [RTG Designer]
[Hum News][Karachi/Islamabad] [Pakistan]
Sent: 10-22-2024 05:50
dim Total as xpTextObject
dim Counter as xpCounterWidget
scene.GetObjectByName("Total", Total)
If Counter.Value < Cing(Total.text) then
Counter.Value = Counter.Value + 1
else
Counter.Value = 1
End if
Sent: 10-22-2024 05:42
Thanks, Red. It's working now. Lastly, I am looking to match the case. For example, when the last table of Excel reaches the end, it matches the counter widget and starts from table 1.
[Wajahat] [Ali]
Sent: 10-21-2024 11:47
live update and requery on the text objects with datalinq?
Sent: 10-21-2024 11:27
What will be engine updTe issue. I am unable to get datalinq update while i played through timeline. Its showing both counter and text updTe in preview. Except on framebuffer except counter.
Sent from my iPhone
Sent: 10/21/2024 10:37:00 AM
Subject: RE: Paging Like Data Shift to next Table
self.Project.GetObjectByName("Counter Name", Counter)
Counter.Value = 0
or 1 or whatever your first value is, put that on the OnOnline.
Sent: 10-21-2024 10:00
Ok, now i have achieved the thing as described.
in next now I have faced another issue is that. the data updated shows the counter widget in the preview and engine except for the Datalinq on the engine. how it can be solved and how to get looped and match when the last table reached. and starts from 1.
and what cmd line will work to reset the counter when the scene gets offlined. which helps to start from the beginning.
[Wajahat] [Ali]
Sent: 10-21-2024 08:23
I would use a widget.
scene.Project.GetObjectByName("Counter Name", Counter)
Then use a macro to get the widget from a text object into your datalinq query.
