Hi Brian
Are you specifically talking about using an Ultrix push-button panel on an Ultritouch or are you referring to another type of Custom Panel?
I don't believe the Ultrix Ultritouch layout has the option to show the name of the panel (though I can capture a feature request for this). One workaround for now would be to use the <editor/> tag to embed the Ultrix panel into a Custom Panel and add any additional controls/information you would like to the pre-built UI. This example panel embeds the editor and adds a label that will show the filename of the custom panel (though you could any text you would like here and even change the size/colour/position of the label).
<abs contexttype="opengear" gridaspect="false" gridheight="203" gridwidth="1304" keepalive="false" touch="true" virtualheight="203" virtualwidth="1304">
<editor bottom="0" left="0" objectid="Ultrix-50225481024<br>Slot 0<br>Ultrix:database:dbcontrol:panels:panel_3" right="0" top="0" widgetroot="true"/>
<label height="21" left="2" name="%eval[ogscript.getFile(ogscript.getAttribute('srcurl')).getName()]%" style="txt-align:west;bg#0000007F;font:bold;" top="1" width="398"/>
You can try this out for yourself - just replace the "objectid" attribute with the node ID of the panel you wish to embed (you will need to replace any "<" with "<" when you copy/paste the node ID). You can get the ID by right-clicking on the panel's node in the DashBoard tree and selecting "View Connection Settings":
James Peltzer
