So this wouldnt work with an API tag that run script on load?
And then set the buttons as disabled there?
We were thinking about covering them with <abs/>, but the buttons themselfs are withing a responsive table that changes size based on the width of the panel, and positioning an <abs/> to cover that is more troublesome than I would like to admit. Though it's only 3-4 buttons on this case, wich would be no hassle to disable. For larger areas and a fixed with panel, that would definetly be my sollution.
Aleksander Stalsberg
Norway
Sent: 03-07-2024 16:51
Subject: Password field - Password protect only portion of a custom panel
You cannot specify enabled/disabled at the time the button is created. You will need to use an <ogscript handles="onload">....</ogscript> block to set your buttons to the correct state when the panel is opened. The most common paradigm I have seen for disabling a large block of controls is to use an <abs/> to cover the part of the application you want to protect and then use the password prompt to hide the <abs/>.
James Peltzer
Sent: 03-07-2024 16:37
Follow up question for you @James Peltzer - How do you also set a button to be disabled on DashBoard opening/load.
Then I can change state of this with the ogscript.setEnabled('ID', true);
Norway
Sent: 03-07-2024 09:28
Hi Aleksander
Yes, there is a hidden widget hint for password fields. If you go into the Parameters dialog, you can modify the hint of any text field and change it to 'password' to get the hidden characters.
Just to note: the password itself is still in clear text and written to the parameter (you'll probably want to also make it stateless by selecting the 'do not save changes made to parameter value' checkbox). This widget hint only changes how it is shown in the user interface.
James Peltzer
