To clarify - I do not need to make these changes from the Kayenne itself. I will have the XPression sitting next to me, I just am trying to avoid a drag and drop mouse movement. I'd like to just type in a takeID in the sequencer, then do some keyboard macro that could assign a take ID to a PBUS register in the map via an input box.
Essentially:
dim takeItem as xpTakeItem
dim pbus as xpPbus
engine.sequencer.GetFocusedTakeItem(takeItem)
pbus = inputbox("Enter the register number.")
takeItem.AssignPbus(pbus)
Jack Reynolds
Sent: 04-28-2025 17:27
Subject: PBUS via API
There is currently no API/protocol to modify the PBUS map in XPression remotely, however, it is an item on our roadmap that we are considering for a future release.
You could look at modifying the XML file that XPression stores the PBUS register in, but I don't think that will work if you're looking for ways to do this from the GVG switcher.
