You can set different item timings, like length of scene director, item timing, group timing, etc. If you're unsure use the fixed item duration and then set the item duration value to the right of item timing.
You can also set groups to trigger at specific times using the timecode/automation tab beside the Group tab in the Take Inspector.
Sent: 06-09-2022 09:02
Subject: Play Through Group in Sequencer
