  • 1.  Position Values Not Showing Until Manually Controlled
    Posted 08-04-2023 22:50
    Hi all,
    I am looking to make it easier for my operators to move headshots/other images around a graphic when in the sequencer. I have written the script below, which gets the focused published object, then will add/subtract a certain amount to the X or Y value, depending on the key pressed. When I run the script, the value does not appear to change initially. When tab down then back up, the value will update, but will not be sent to the graphic until I manually click into the XY value fields. Is this just a limitation of XPression in that the values don't actually send to the graphic until the up/down arrows are manually pressed? Or is there a way around this?
    To be clear, the script does work, and it does send the correct to the sequencer. The graphic just does not reflect it until I press up/down on the positioned values.
    dim pub as xpPublishedObject
    dim name as string
    dim name2 as string
    dim x as double = 0
    dim y as double = 0
    dim z as double = 0
    dim propName as string
    dim propType as double
    dim index as integer
    'Get the TakeID of the focused sequencer item.
    engine.sequencer.GetFocusedPublishedObject(pub)
    name = pub.Name
    name2 = name.ToUpper
    for index = 0 to 2
    	pub.GetPropertyInfo(index, propName, propType)
    	if propType = 1 then
    		if propName.ToUpper.Contains("POSITION") then
    			pub.GetPropertyVector(index, x, y, z)
    			dim newY
    			newY = y + .01
    			pub.SetPropertyVector(index, x, newY, z)
    		end if
    	end if
    next
    Jack Reynolds
  • 2.  RE: Position Values Not Showing Until Manually Controlled
    Posted 08-30-2023 15:59
    Are you running this from the keyboard map?
    When you say "will not be sent to the graphic" and "don't actually send to the graphic" - are you talking about the graphic in the preview window in Sequencer or a graphic that is online in Sequencer?
