Not exactly what you asked but it should help you get started with scripting lines.
Here is a script I used to create an animated graph a couple of years ago.
dim Lines1, Lines2 as xpLinesObject
dim count as xpTextObject
scene.GetObjectByName("Lines1", Lines1)
scene.GetObjectByName("Lines2", Lines2)
scene.GetObjectByName("Count", count)
dim c as integer = count.Text
dim tPoint, ctPoint as xpTextObject
dim x as integer = 1180 / c
dim y as integer = 10
Lines1.SetCurrentList(0)
Lines1.ClearCurrentList
Lines1.BeginUpdate()
Lines1.AddPoint(0, 1000, 0, 5)
dim i as integer
for i = 1 to c
scene.GetObjectByName("tTicket" & i, tPoint)
dim t as integer = tPoint.Text
engine.DebugMessage(tPoint.Text, 0)
Lines1.AddPoint(i*x, t*y, 0, 5)
Next
'Lines1.AddPoint((c+1)*x, 0, 0, 5)
Lines1.EndUpdate()
Lines2.SetCurrentList(0)
Lines2.ClearCurrentList
Lines2.BeginUpdate()
Lines2.AddPoint(0, 1000, 0, 5)
for i = 1 to c
scene.GetObjectByName("ctTicket" & i, ctPoint)
dim t as integer = ctPoint.Text
Lines2.AddPoint(i*x, t*y, 0, 5)
Next
'Lines2.AddPoint((c+1)*x, 0, 0, 5)
Lines2.EndUpdate()
Sent: 01-17-2024 11:26
Subject: Primitive Lines script to link to X & Y of another object - To control the location of the end point
Hi Ross Community-
We need some help linking the end point of a Line to another object, so our producers can control the end point location on the map. See screen shot below. Has anyone done something like this that they could help us with a script?![](https://higherlogicdownload.s3.amazonaws.com/ROSSVIDEO/MessageImages/a7f6d61b64c94db9bfc49b36f5bc2265.png)
SS Blank
KSL TV5
