Assign a material to the quad. Give it a texture too. You can make the default texture completely transparent.
Note, unless you are making something that is supposed to look 3D, shaded, and almost real, I recommend making diffuse black and emissive white.
Azathoth
Son of Cthulhu
Sent: 07-31-2024 13:42
Subject: Quad image stretching
Usually importing PNG assets into Xpression draws transparent backgrounds masterfully, but this seems to involve a quad as a placeholder maybe? The quad shows up as the blue and yellow checkerboard placeholder look and I couldn't find any properties on it being transparent or colored.
Sent: 07-31-2024 05:17
The standard is transparent when using boarder so there must be something else going on if it's black.
Sent: 07-30-2024 17:19
Awesome! It kept the image's integrity intact! It did add a black background for the remainder of the quad placeholder space, so is there a way to have it transparent instead of black? If it's not possible, this result is much better than previously set. Thank you, Azathoth!!
Jo Hern
KVOA
Sent: 07-30-2024 16:58
On the quad go to Texture Coords.
Under Misc. you have mode. Select "Border".
Azathoth
Son of Cthulhu
