Sounds like something I need to try.
Best regards Tue.
Sent: 01-08-2024 16:18
Subject: quad with image that is updating?
When using files on disk, XPression will reload the texture in cache if the last modified time changes. This setting is controlled here:
XPression > Edit > Preferences > Texture & Image Cache > 'Reload textures when the file's last modified time changes'.
This feature isn't working here because the image is coming from a URL.
But if you did what Azathoth suggested and downloaded the image in a loop to disk, then this setting in XPression would continually update the image as the file was modified.
Sent: 01-08-2024 10:12
I tried doing a couple simple things, but they didn't work. Xpression is caching.
I haven't had a chance to try this, but maybe set up a loop that has a script in it. The script would download the image to a predefined name(s). Maybe use two different names and materials. Switch between materials linked to the images after download. This might get around the caching problem.
Azathoth
Son of Cthulhu
Sent: 01-05-2024 10:04
It is this image.
I tryed to make an xml file with the link, and added it by datalinq, but it does not update the picture when I load the graphic.
Any suggestions, on how to?
Tue Sandbæk
Director / TV-Technician
TV SYD
Sent: 12-21-2023 12:55
You could set up a computer to do a CRON job that downloads the image as a file that is used as a texture.
However, you then might have a caching problem where Xpression doesn't know the image is updated.
Azathoth
Son of Cthulhu
