Hi Eduardo,
You can set your carbonite as the data source of your panel and view the available parameters of the device.
If the source is available as a parameter, you can use params.getValue(oid, Index) to get source. Please find images below on how to view the available parameters.
Setting the data source:
To view the parameters, Select Params then select default. Drag a box on the panel and parameters will be display. You can search the source and the oid will be show in parentheses.
Thank you,
Aury R.
Aury Rukazana
Senior Software Developer
