Hello all,
I have a question related to the internal clock of the Carbonite Ultra. I can find two clocks in the menus: one under Status/Power menu, and the other in Configuration/System/Global. The first one is in sync with our reference input. The second one can be edited manually.
My issue is that the second one is used in switcher logs and each day is a second off. And if I forget to update it regularly, sometimes is off by several minutes. And obviously it doesn't follow the daylight saving time, that adds another hour.
Is there a way to link it to the other clock, that is in sync?
Thank you!
Sorin Podeanu
technical director
Euronews Romania
