Thank you so much for letting me know by attaching a picture!
I'll practice it and check it out.
Thank you for your kind explanation
Have a great day!
Dongkeun Han
Employee
Youngdo B&C
[Seoul] [Republic of Korea]
Sent: 08-05-2024 21:50
Subject: Question about XPression cameras function
You can change what camera is being viewed in the Viewport by selecting the Camera dropdown in the top left of the viewport, then select the camera you would like to view from.
Separately, you can change what camera is being used to render the scene to an output by setting the camera to "active" in the settings:
Finally, you can use a specific camera in a RenderView shader as part of a material
Zachary Fradette
United States
Sent: 07-31-2024 19:53
Thank you so much for your response.
Is it a feature that can be viewed through rendering when using a 3D object?
So you're sending the scene to the camera's viewpoint, not the front?
Dongkeun Han
Employee
Youngdo B&C
Sent: 07-31-2024 05:14
Camera's are so you can move around there scene in 3D and choose a different angle to view from and take on air from.
You can also use them for renderviews.
