Can a RCP-NKQ or any other RCP control outputs on a non Ultrix Ultra?
Yes you can use the RCP devices -- if they are not the Ethernet Q units (so the NKQE) then you will need an NK-NET to plug into it or an IPS in the system to act as the bridge to ethernet.https://help.rossvideo.com/carbonite-device-db/Topics/Hardware/Aux-Panel/Ross-RCP-NK1.htmlFor ethernet panels use this example of the ME model. works the same.https://help.rossvideo.com/carbonite-device-db/Topics/Hardware/Aux-Panel/Ross-RCP-ME.html
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
