Sent: 07-03-2023 07:52
Subject: Read Folder List in Dashboard
Frankly there is a ton of "traps" when it comes to reading files from a folder... I've been working on someting similar earlier this summer, and found most of them, I hope...
Anyways, below is the code for a dashboard that will look up the files in a folder names "images" in the same folder as your DashBoard, regardless of where it is on whatever computer you copy it into, and then updates a dropdown with a choice constraint like you ask for above.
<abs contexttype="opengear" gridsize="10" id="_top" keepalive="false" style="">
<meta>
<params>
<param access="1" constrainttype="INT_CHOICE" name="selectFile" oid="selectFile" precision="0" type="INT32" value="0" widget="combo">
<constraint key="0">---</constraint>
</param>
</params>
</meta>
<button buttontype="push" height="70" left="30" name="Get Files" top="30" width="100">
<task tasktype="ogscript">var dashURL = decodeURI(ogscript.getPanelRelativeURL('images')); //Get the full path to /Images folder wherever the dashboard is.
var files = ogscript.post(dashURL, null); // Get an array of files in the folder in the line above.
if(files != null) { //Check if the folder exists at all.
files = files.split('\n'); //create array from return if folder exists.
if(files.length > 1) { //Check if number of files is greater than 1. Empty folder still returns as 1 file with value of ''.
var index = files.indexOf(''); //Get the index of the '' value entry in array
if(index > -1) { // Only splice array if item is found
files.splice(index, 1); //Remove the found '' (if any), and one item only.
var arr = ['---']; //Prepare emtpy array for key/value pairs. I usually add '---' at the top for an "empty" choice for the dropdown.
for (var i = 0; i < files.length; i++) { //Go through each entry in the array and push key/value pair into the prepared array.
arr.push({key:i,value:files[i]});
var choiceConstraint = params.createIntChoiceConstraint(arr); //Create an intChoiceConstraint from the key/value array.
params.replaceConstraint('selectFile', choiceConstraint); //Replace the choice constraints in the dropdown parameter with the choice constraints created above.
params.setValue('selectFile', 0, 0); //Set the choice in the dropdown to the first option wich would be --- in this example.
} else {
ogscript.debug('Folder is empty...');
else {
ogscript.debug('Folder does not exist...');
}</task>
</button>
<param expand="true" height="30" left="130" oid="selectFile" top="120" width="220"/>
<label height="30" left="30" name="Select: " style="txt-align:east" top="120" width="100"/>
<label height="70" left="150" name="<html>For this to work, you must have a folder names "images" in the<br/>same folder as your dashboad.</html>" style="txt-align:west;" top="30" width="470"/>
Have fun! :D And do keep us posted about what you're doing. Allways fun to see end results.
Aleksander Stalsberg
Norway
Sent: 07-01-2023 15:54
iam not a software engg to write a code , but i found this is so useful for me , can you suggest me how can i get those file as constraint value in dropdown list rather then in debug . if i can get in dropdown then i can easly solve my broadcast problem alot.
sunil Blank
Freelancer Graphics Designer
Freelancer
Sent: 11-21-2022 10:44
Yes - the code expects a URL format. I used the '.' to list the current directory (you can also use relative URLs for sub-folders in the same parent as the panel). If you want to browse arbitrary locations on the drive, you will need to use the file URL format.
James Peltzer
Sent: 11-21-2022 10:20
Thanks. Works great except I had to add the protocol:
var files = ogscript.post("file:/D:/Clients/UserGraphics", null).split('\n');
JohnCorigliano
Senior Software Engineer
ISC
Sent: 11-18-2022 16:20
Hi John
For your local filesytem, you can use ogscript.post('FILE_URL_GOES_HERE', null); to get a list of filenames (one name on each line).
var files = ogscript.post('.', null).split('\n');for (var i = 0;i < files.length; i++){ ogscript.debug(files[i]);}
James Peltzer
