Hi Arnaud,
I have a small custom panel I've created that connects to a Furio. It toggles the axis from enabled/disabled and send a Preset ID.
You may have this to see how it works with your system and if it's something that would interest you, we can discuss a further build out of a panel.
You must enter the IP of the Furio and select the connection button to get started, if you open the Dashboard debug window you will see any replies from the Furio for enable/diasble of the axis and also for sending the presets. Enter the preset ID to send the preset. NOTE the duration isn't provided in the preset messages, it will use the default value.
https://public.3.basecamp.com/p/yGP87AHGagN16rNCXANcq3tu
Best regards,
Richard
Richard Crutwell
Ross Video UK
Sent: 09-19-2024 03:43
Subject: Recall a Robotic Preset from dashboard - Only one axis
Hi Richard,
Thanks for your answer. I already control the Furio from Dashboard (and from the shotbox with custom controls). It works very well.
But, when you record a preset, it contains all the axis of the robotic system (pan, tilt, zoom, focus, lift, track).
Smartshell and Dashboard don't allow you to filter axis or choose the axis you want to recall. You must recall the full preset .
I succeed in recalling just one axis of the Furio with Smartshell using Moves but I can't do this from Dashboard.
If you find the command, it would be really help us.
Best regards,
Arnaud
Arnaud JACQUET
chief of the camera operator
RMC BFM
Sent: 09-17-2024 05:49
Hi Arnaud,
There may be a direct string that can be sent to the Furio or Robotic Server, I'll take a look and let you know.
In the meantime, have you attempted adding the Furio to Dashboard:
- if you can open the Dashboard panel once added, you can recall presets from there.
- - Alternately, you can add the Furio as a device to a custom panel once added in the Dashboard tree.
Best regards,
Richard
Richard Crutwell
Ross Video UK
