Infrastructure​
  • 1.  Recording PGM out(MC-1) on XDS-PD1000 XDCAM Recorder result in no audio.
    Posted 07-07-2025 10:35
    We have XDS-PD1000 XDCAM Recorder. When I try to record MC-1 PGM out on XDS-PD1000 it results in no audio on all 8 chanels on XDCAM Recorder.
    I have deleted all routing levels below level 5 .
    According to manual:
    "The remaining audio channels within the SDI stream are still there and even though they are not
    explicitly defined within the logical map. They will remain at a default routing of 1-to-1 (i.e.; input #1
    embedded channel #8 will always be routed to output #1 embedded channel #8). It may be
    undesirable to have these extra embedded audio channels routed this way, so a "Disconnect" may
    be defined for the input channels not required."
    My problem is that i can't set a "Disconnect"  for the input channels not required.
    VID 20250706 122249
    YouTube remove preview
    VID 20250706 122249
    Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
    View this on YouTube >
    What I am doing wrong? :)
    Artur Szutenberg
  • 2.  RE: Recording PGM out(MC-1) on XDS-PD1000 XDCAM Recorder result in no audio.
    Posted 07-15-2025 17:44
    Long shot but double check that the audio input on the XDS is set to SDI and not AES.
    Paul
