Nice work. Visual Basic is a handy tool to have in your toolbox. I'm glad you gave it a shot.
Sent: 01-06-2024 11:51
Subject: Reformatting names with visual logic
It works! Thank you so much, I am going to try and teach my self some visual basic as it seems like scripting gets more and more useful.
Philip Doherty
Elon University
Sent: 01-06-2024 11:46
you would put this script on the text field in your scene that is linked to your data. No variables needed. It looks at the text and finds any commas, then uses that to split the string and flip the order. If there are no commas, it just passes the name through. It's pretty slick. Be sure to compile the script afterwards. (little orange logo in the script window up at the top)
Malcolm Thorpe
xpression design
Sent: 01-06-2024 11:41
I am relatively new to scripting, should I put this in the object, or the scene itself? Also, do I need to declare any variables beforehand?
Philip Doherty
Elon University
Sent: 01-06-2024 11:38
The script is only 5 lines of code if you want to try it.
if InStr(text, ",") > 0 then
text = split(text, ",")(1) & " " & split(text, ",")(0)
else
text = text
end if
Malcolm Thorpe
xpression design
