Okay, I think we have a better handle on what's going on.
We just need to "Activate" the project that Remote Sequencer deploys to the Studio and the script is there and works.
We now have an XML Take Item List saved with the items to import.
Thank you all for your help!
Scott Thomas
Art Director
WINK-TV
Sent: 10-13-2023 14:28
Subject: Remote Sequencer vs. Studio
Thanks Jeff for the clarification. I'll look into the XML Take Item List. We tried moving the Script Action to the Globals, but it stopped working. We'll try that again.
Scott Thomas
Art Director
WINK-TV
Sent: 10-13-2023 13:42
Scott,
The behavior you're seeing is consistent with the XPression MOS workflow involving a Project Server and Remote Sequencer. What are you trying to accomplish with the Keyboard Shortcuts and Sequence Group?
You are correct that when a running order is activated on the XPression Gateway, any associated project will open in XPression but not become active, nor will take items saved to the project open in the sequencer. Your sequence groups could be saved as an XML take item list that the Director or XPression Operator could open after activating the deployed project in the Project Manager's Project Group. This would need to be done each time the project gets unloaded and reloaded into the Studio engine, but would alleviate the need to open the project twice.
Then depending on what functions your keyboard shortcuts target, they could be loaded into the Global Shortcut section so they'd be available to the engine regardless of the active project. If your operator is working from remote sequencer, it's possible to create a different set of keyboard shortcuts on that program that may accomplish similar tasks.
Jeff Mayer
