Sent: 09-18-2023 03:52
Subject: Remove watermarks from a demo created project
Thank you, I don't want to display some other text, but the same text (Text1) to hide more than 3 lines.
Is it possible?
Chris
Chris Panagopoulos
Sent: 09-15-2023 10:33
In this example I have set the second text box to turn on if the height of the first text box is under 72.
The value is 72 because the each line of my text using that current font gives a height of 71.
So when its 1 line text 2 is vis, when it goes to 2 it turns off.
Sent: 09-15-2023 09:58
This is an answer for the second question I suppose... You can do what you require using visual logic, are you family with it?
No, I thought that it clould be a setting option at the block. Have you any ideas how to do with visual logic? Do you mean to limit the charakters of the text or something like this?
Tnx
Chris Panagopoulos
Sent: 09-15-2023 09:49
You cannot remove the water mark to my knowledge.
