RenderViewers from scenes not online will work, I use them for things like wipes.
The difference is I am updating the content such as team names and logos from external data so this gets updated.
You are trying to update from the sequencer that is technically a copy of the scene, not the scene itself.
Sent: 03-19-2024 17:54
Subject: Renderview shader not updating published text in sequencer
That works great when the text is in the same scene as the renderview, thanks!
is there a way to make the renderview grab view from a scene either on another layer or not online work between scenes?
Ronen Lasry
FULL MENTAL JACKET
Los Angeles United States
Sent: 03-19-2024 14:28
Have you tried owner scene for your tests where the text and render view are in the same scene?
I asked because I use this method a lot and I am able to change the text.
Sent: 03-19-2024 14:09
Hi, I'm referring to the scene not owner scene
I'm working on a virtual set in xpression and the design calls for a curved screen with motion graphics and data content playing on it - the graphics and data would be updated from the sequencer
so I thought a renderview material would be the only way to achieve this
attached is my test xpf file
appreciate your help Simon!
Ronen Lasry
FULL MENTAL JACKET
Sent: 03-19-2024 05:29
When you are doing within the same scene are you using owner scene? for the render view?
