  • 1.  Renderview shader not updating published text in sequencer
    Posted 03-18-2024 19:10
    Hi I am trying to sort out how to get renderview shaders to update text in sequencer when text field values are changed and taken to air
    attached are a few screenshots that hopefully show the behavior I am seeing
    look forward to your suggestions!
    Ronen Lasry
    FULL MENTAL JACKET
    Los Angeles United States
  • 2.  RE: Renderview shader not updating published text in sequencer
    Posted 03-19-2024 05:29
    When you are doing within the same scene are you using owner scene? for the render view?
  • 3.  RE: Renderview shader not updating published text in sequencer
    Posted 03-19-2024 14:10
      |   view attached
    Hi, I'm referring to the scene not owner scene
    I'm working on a virtual set in xpression and the design calls for a curved screen with motion graphics and data content playing on it - the graphics and data would be updated from the sequencer
    so I thought a renderview material would be the only way to achieve this
    attached is my test xpf file
    appreciate your help Simon!
    Ronen Lasry
    FULL MENTAL JACKET
    Attachment(s)
    xpf
    test_renderview1.xpf   192 KB 1 version
  • 4.  RE: Renderview shader not updating published text in sequencer
    Posted 03-19-2024 14:28
    Have you tried owner scene for your tests where the text and render view are in the same scene?
    I asked because I use this method a lot and I am able to change the text.
  • 5.  RE: Renderview shader not updating published text in sequencer
    Posted 03-19-2024 17:54
    That works great when the text is in the same scene as the renderview, thanks!
    is there a way to make the renderview grab view from a scene either on another layer or not online work between scenes?
    Ronen Lasry
    FULL MENTAL JACKET
  • 6.  RE: Renderview shader not updating published text in sequencer
    Posted 03-20-2024 05:42
    RenderViewers from scenes not online will work, I use them for things like wipes.
    The difference is I am updating the content such as team names and logos from external data so this gets updated.
    You are trying to update from the sequencer that is technically a copy of the scene, not the scene itself.
