If you can get the data from your URL via XML instead of JSON, I could look to help you write an XSLT (XSL Transformation file) that would load in along-side the XML you get in your data to produce a transformed result.
Sent: 08-09-2024 09:38
Subject: Reordering JSON data dynamically
Hi Jeff,
I hope you are well. I am returning to this for another project but have little luck with it working. I believe I am doing everything correctly. Can you look at this screenshot and let me know what you think?
Jordan Allen - Mix Effect Media XPression
London United Kingdom
Sent: 05-09-2024 09:45
Match Multiple Search Criteria
The XML/JSON datalinqs can now search multiple attributes or elements to return a node that matches all search criteria. e.g. players<team=NY;jersey=10>
Look For Increments of an Index Value or Search Criteria
A DataLinq comparison key such as <club=ross> can now have an additional index parameter as well, like so <club=ross<2>>, which will retrieve the second item matching the key.
Search Through Child Elements and Attributes
The XML datalinq types can search for children elements/attributes in a level of the tree by using "childname.field=%key%". e.g. player<info.jersey=%num%>\name
Find the Highest Index Value of an Element
The <index> field can now use the keyword "max" to return the element from the highest array index. e.g. scoring\plays<max>\description will return the description from the highest play element. <max-1> would return the second highest element, etc
Jeff Mayer
Sent: 05-09-2024 05:56
This is great. Thank you for this. Can you also do the same for <min>, or is it exclusive to Max value? I tested it with <min>, and it didn't seem to work.
Do you have some document that lists all these functions for the <index> for future reference?
Sent: 05-08-2024 11:34
In Version 10.5 and higher, You can use <max>, <max-1>, <max-2>, etc., to find the highest, second highest, third highest element, etc., in your array:
in DataLinq, when searching for data in a tree based DataLinq, the <index> field can now use the keyword "max" to return the element from the highest array index. e.g. scoring\plays<max>\description will return the description from the highest play element. <max-1> would return the second highest element, etc.
Jeff Mayer
Sent: 05-07-2024 07:47
Do you know anyone who knows Python? They could make you a file that reoarders the json file.
Alternatively I think you'd need to reorder once its inside XPression already.
What are you try to do because you can do pretty decent searches on XML that I think would work on json such as;
team\player<<2>oncourt=Y>\stats
