What is the resolution of the panel you want to use? DashBoard prefers a 1920x1080 resolution.
From there, it's more about your computer's ability to communicate with the panel than Dashboard. Can you get the right drivers so that the computer can be controlled by the touchscreen?
Worse case, just try it! DashBoard is free and if you already own the hardware, there isn't much harm in giving this a go.
Good luck!
Joe Davenport
Solutions Architect
