So when changing the resolution it will convert any scenes that are 1080 to 720 I believe.
In terms of I to p its about frame rate, if 30fpd becomes 60fps expression will do its best to adjust keyframes but videos may run fast or slow depending on their frame rate and continuous animations will also need adjusting for timing.
