https://www.rossvideo.com/resources/ross-university/two-box-effects-using-effects-dissolve/
that one shows how to make effects dissolves box effects.
Sent: 01-17-2025 21:01
Subject: Ross Carbonite Ultra - 2 Box Pull
Is there any documentation or tutorials on how to accomplish this?
We haven't used memories before so if there's a helpful bit of information available it would be really appreciated.
Andrew Marchand
Live Broadcast Engineer
Toronto Canada
Sent: 01-17-2025 19:57
You can use the memory system to do this the same way.
ultraScene recalls include all scenes and can change layer assignments between scenes.
using memories you can still perform effects dissolves via memories and setting attributes. The only difference is that a memory can not change the assignments of layers to the scenes.
