I have two Acuities in separate control room that need to send RossTalk commands to the same device. The listening device can only listen on a single port.
Does Acuity RossTalk establish a continuous connection to an IP:Port? Or does it connect, send a command, then disconnect?
If it's the latter, then I'm hoping I can use the Acuity to communicate directly with the device with the caveat the Acuities cannot be used simultaneously.
Background:
I'm connecting to a BTI Ticker product which accepts triggers via socket byte strings which is how RossTalk works. RossTalk works far better than the custom Python script I was building instead. My question is purely about connectivity and whether the Acuities can both connect to the same device:port using RossTalk. If not, I can use Dashboard as intermediary. Essentially: Acuity --> (RossTalk) Dashboard --> BTI. For simplicity, I'd like to leave Dashboard out if possible.
CrossPosted: Facility Control
Kurt Stoneburner
Broadcast Director
KGO-TV
