A custom control on a carbonite will only stay lit while it is running. So if the custom is short, you will not see it lit up for long. - If the custom is on a button that does not have a physical button on a panel, then you will not ever see it lit up. - If it has a hold built into the custom, then you would see that button flashing obviously. - You can also have the custom control window open to the carbonite in a dashboard and you can see the numerical of how many customs are currently running. And you can see that go to 1 or however many you are trying to fire.
Garrett Hall
Overtime Elite
Sent: 04-13-2023 11:11
Subject: Rosstalk with ProPresenter
Figured it out. Found out that the Custom Controls were firing but I didn't see the change of the buttons on the Ross so I thought they weren't working.
Is there a way for the Ross Carbonite to show what custom control is active when a command from another board or ProPresenter fires a command?
Scott Behrends
