Hi Tina,
Roma is correct, this is pretty easy to do with a script, but if you are more comfortable with Visual Logic, you can get the same result.
The Round Function will only round to the nearest whole number so you will not be using it for this.
The first step would be to isolate the decimal. You can do this with a String Position block. You will then want to add two digits after the decimal location as you want this to show to the hundredths. Finally, run your product from your Multiply block to a Left String block's In and the total of the String Positions and offset/Adds block into the Length of the Left String. The out of the Left String can then be run to the final text field.
Hope that helps,
Rob
Rob Blank
