Hello, first time posting here and i have a question about salvo ID and recalling via buttons on an Ultritouch. Everything is setup and working but I'm seeing some strangeness that if i recall a salvo via its ID not referencing the correct salvo, instead its recalling the salvo in the order of the list.
I created a list of salvo and then deleted and added a couple of salvo so my id ordering is weird in the list, it looks like this
Default Salvo [0]
Salvo [2]
Salvo [3]
Server OP Default [1]
Salvo [5]
202 RP 102 [5]
202 RP 103 [6]
202 RP 104 [7]
202 RP 105 [8]
202 RP 106 [9]
203 RP 102 [10]
203 RP 103 [11]
203 RP 104 [12]
203 RP 105 [13]
203 RP 106 [14]
When I try to recall "Server OP Default [1]" using the ID1 does not work that recalls the second item in the list, when I recall ID3 it recalls doesn't recall ID3 it recalls the fourth item in the list (Base 0)
Can anyone tell me if this is correct behaviour, am I missing something or is it a bug?
Many thanks
Andy Coates
Andy Coates
Technical Producer
seventhree
