  • 1.  Saving Switcher Config
    Posted 10-24-2024 14:46
    Greetings,
    We are having issues with our switcher settings saving. We have a setup where we use automation as well as manual configurations. Therefore, we switch back and forth between the two of them. We do this by loading the switcher settings specific to either the manual or automation sets.
    As of late, changes to the memories do not save and recall even after saving the sets in dashboard.
    Also, we have made naming changes to the inputs on the switcher and they too do not stray saved.
    Can someone one help?
    Andre Sanders
    Technical Media Producer
    WUFT
  • 2.  RE: Saving Switcher Config
    Posted 10-24-2024 14:47
    Not sure if this matters but we have the Touch Drive Switcher Panel.
    Andre Sanders
    WUFT
  • 3.  RE: Saving Switcher Config
    Posted 10-25-2024 05:47
    Andre,
    This sounds like a fault condition and it is not normal behaviour. I would recommend that you contact our tech support dept directly and they will help you identify the issue and resolve it.
    Rossvideo.com/support
    Nigel Spratling
  • 4.  RE: Saving Switcher Config
    Posted 10-30-2024 09:18
    Will do. Thanks Nigel!
    Andre Sanders
    WUFT
