Sent: 04-25-2023 06:53
Subject: Scene Control Crawls
OK can I get this straight, as its not working.
On my text child scene I have an event marker. At the beginning of the text row.
On Show
O speed ticked
On hide speed 2 ticked
Then event eyeball off at 0, off at 87 then on at 88?
To trigger crawl?
This doesn't seem to work?
I've got alpha green and visible ticked in key frames?
Help.
Sent: 4/24/2023 1:59:00 PM
Subject: RE: Scene Control Crawls
In this case, you would need to set a keyframe on the Anim Controller that would turn on the eyeball (visibility) for the event marker.
Rob
Rob Blank
Sent: 04-24-2023 13:41
Hi Red thank you
Can I ask how do I link the Event marker to the Animation controller?
H x
Helen
Sent: 04-24-2023 12:20
Put an eventMarker in your scene, set speed to 0 onShow and then to the speed you want onHide or whatever setting you want such as play or pause or whatever.
Make an animation controller that sets the visibility to change on the eventMarker on the frame you want.
