Thanks for all your help. I will do that.
Sent: 3/17/2025 4:20:00 PM
Subject: RE: Scene Director
Cool, np I wanted to be sure.
So yes for me it works every time.
You could open a ticket with our tech support to check your machine.
Sent: 03-17-2025 16:08
Subject: Scene Director
I mean when I click on it on the sequence side it plays
Sent: 3/17/2025 4:05:00 PM
When you say played the file what do you mean?
Sent: 03-17-2025 15:37
I played the file now and it's working. But later it might not. I don't get it. Version 8.5. We are upgrading in 3 months or so to version 12.
Sent: 3/17/2025 3:34:00 PM
What version are you on?
Sent: 03-17-2025 15:26
Im. sorry. It does the same thing. It plays until the last slides and stops. It does not go back to the beginning. Our engineer said he is going to take a look at the RAM. Is there a way to clear clean out memory or cache files.
Sent: 3/17/2025 3:22:00 PM
What do you mean by nothing?
Sent: 03-17-2025 15:09
I took out the script and nothing.
Lazaro Lopez
TV/DIRECTOR/EDITOR
MIAMI DADE COUNTY
Sent: 03-17-2025 13:10
I see you have a script on online to play the scene director, why is that? default will play anyway, is that perhaps messing with your scene?
Sent: 03-17-2025 13:04
It's not working again. I did what you told me to do and nothing. Can the file be corrupt?
Lazaro Lopez
TV/DIRECTOR/EDITOR
MIAMI DADE COUNTY
Sent: 03-17-2025 08:53
That's a good level of performance, pretty low actually so it's not that.
This is just a thought but try putting a another reset 1 or 2 frames after the current one as a safety just incase the other one is being jumped for some reason as a work around for now.
Sent: 03-17-2025 08:44
It fluctuates from 29 to 31 percent. The scene director is playing correctly now. Later, who knows what it's going to do.
Sent: 3/17/2025 6:39:00 AM
What is the performance meter of your system saying when the graphic is playing?
Sent: 03-17-2025 06:29
i tried it again and it played just fine. Then I played it 5 minutes later and it got stuck again. It would t go back to the beginning. Maybe it's our system?
Sent: 3/17/2025 5:24:00 AM
I downloaded your scene and I play it out on my system and it restarts as you would expect. I did move the restart earlier in the timeline for testing purposes, have you tried that.
Sent: 03-14-2025 15:59
i added a video.
Lazaro Lopez
TV/DIRECTOR/EDITOR
MIAMI DADE COUNTY
Sent: 03-14-2025 12:58
When i click on the sequence to go on AIR... It plays fine until the end, and stops on the last commissioner slide. it doesn't go back to the beginning.
When i open up scene director to check it...it plays fine and goes back to the beginning.
thank you
Lazaro Lopez
TV/DIRECTOR/EDITOR
MIAMI DADE COUNTY
