Hi all.
Michelle, it's so easy. Create a new scene director. Move the background animation to the new scene director (in the previous scene director, leave only the title animation with the pause event). Set the old scene director as default. Add a Scene Director trigger Into the previous Scene Director, that should run to play the new Scene Director. If you want your background to play in a loop, add an event with "Jump to frame - 0" to the end of the background animation. After everything you have done, start your scene in the sequencer by pressing Enter on the numpad. Then press Enter on the numeric numpad again to continue the animation.
Roman Yaroshenko
chief specialist
RBC-TV
Moscow Russian Federation
Sent: 11-02-2022 20:14
Subject: Scene Director - Pause
Hello.
So I must just be missing something here, but for the life of me I don't quite understand this. So I make a new scene then do I add a background from the base object in the objects library? Is that what you mean by make a scene that is my background?
Then if that is correct, I would go to the materials manager and create a new material and make it a renderview material.
I will stop there to see if I am even on track.
Michele Lee Hampton
Graphics Operator
Hermosa Beach, CA
Sent: 11-02-2022 16:44
Make the background a renderview.
As in, make a scene that is your background and then use it as a renderview material in all your scenes that need that background.
