Hi there, currently have a script which is providing output of line graphs for AFL player stats, using Xpression Graphite v8.5 4567 (64bit)
(script below).
'create a new XPression engine instance
'dim Engine as new xpEngine
'dim a material variable
dim Mat as xpMaterial
'dim an APITexture shader variable
dim Texture as xpAPITextureShader
'dim and create a Pen object instance
dim Pen as xpPen
Pen = Engine.CreatePen
'dim and create an xpPointList object instance
dim Points as xpPointList
Points = Engine.CreatePointList
dim y1 as xptextobject
dim y2 as xptextobject
dim y3 as xptextobject
dim y4 as xptextobject
dim y5 as xptextobject
dim y6 as xptextobject
dim n1 as xpBaseobject
dim n2 as xpBaseobject
dim n3 as xpBaseobject
dim n4 as xpBaseobject
dim n5 as xpBaseobject
dim n6 as xpBaseobject
self.getobjectbyname ("Value 1", y1)
self.getobjectbyname ("Value 2", y2)
self.getobjectbyname ("Value 3", y3)
self.getobjectbyname ("Value 4", y4)
self.getobjectbyname ("Value 5", y5)
self.getobjectbyname ("Value 6", y6)
self.getobjectbyname ("node 1", n1)
self.getobjectbyname ("node 2", n2)
self.getobjectbyname ("node 3", n3)
self.getobjectbyname ("node 4", n4)
self.getobjectbyname ("node 5", n5)
self.getobjectbyname ("node 6", n6)
'retrieve "material1" from the project (see assumptions above)
Engine.GetMaterialByName("line 3", Mat)
'retrieve the APITexture shader from the material
Mat.GetShaderByName("APITexture", Texture) 'set the Pen's size to 20
Pen.Size = 5 'set the Pen's color to red and alpha to full
Pen.SetColor(255, 255, 255, 255) 'now using (disconnected) line mode we draw a number of lines representing a graph
'note: to prevent redrawing on each line instruction we call Begin/EndUpdate to improve performance APITexture.BeginUpdate() APITexture.MoveTo(100, 100) APITexture.LineTo(Pen, 200, 150) APITexture.LineTo(Pen, 300, 100) APITexture.LineTo(Pen, 400, 200) APITexture.LineTo(Pen, 500, 400) APITexture.LineTo(Pen, 600, 100) APITexture.EndUpdate()
' Dim points As New xpPointList
dim factor as double
factor = "21"
texture.clear
Points.AddPoint(0, cdbl(y1.text)*factor)
Points.AddPoint(160, cdbl(y2.text)*factor)
Points.AddPoint(320, cdbl(y3.text)*factor)
Points.AddPoint(480, cdbl(y4.text)*factor)
Points.AddPoint(640, cdbl(y5.text)*factor)
Points.AddPoint(800, cdbl(y6.text)*factor)
n1.posY = (cdbl(y1.text)*12.7)
n2.posY = (cdbl(y2.text)*12.7)
n3.posY = (cdbl(y3.text)*12.7)
n4.posY = (cdbl(y4.text)*12.7)
n5.posY = (cdbl(y5.text)*12.7)
n6.posY = (cdbl(y6.text)*12.7)
'now draw the lines using the PointList APITexture.DrawLines(Pen, Points)
So the use case is the operator wants to be able to see the resulting output before taking the scene to line, but in having this option present, when these graphics play back to back, the line material changes live in output when the next scene in sequence is previewed, which is not desired.
I suppose I am asking how to add to this script, a modifier to the material that outputs the line graph, to reference another material as the desired output instead of only referencing one material.
The operator currently duplicates the scene and creates a new material and changes the script to that material, but this is creating a lot of additional templates (20 unique and now 20 duplicated) and slowing workflow.
What would be a better alternative?
Cheers
T
Tai Newman
Xpression operator/designer
Melbourne Australia
