Clearing the list first solves the loop problem if you play more than once.
If you add a material and then turn off spline you'll see the object is still actually there.
Sent: 11-12-2022 20:14
Subject: Scripting Line Object Point List
Hi again @Simon Redmile, I kinda forgot about this one for a while.
Had way more to do, but I'm kinda back to this one one...
I'll send you the .xpp for my problem. The script is in the scene director, and it "works" in the way that it adds the points to the line, however it only shows up if "use spline interpolation" is on... And I'm looking to not wanting that.
The script looks like this:
dim Lines1 as xpLinesObject
dim Line1 as xpPointList
scene.GetObjectByName("Lines1", Lines1)
Lines1.SetCurrentList(0)
Lines1.BeginUpdate()
Lines1.AddPoint(0,0,0,10)
Lines1.AddPoint(200,200,0,10)
Lines1.AddPoint(300,0,0,10)
Lines1.EndUpdate()
Any and all help would be really appreciated...
I'm trying to create a radar chart, and for that I would need to at least be able to create the outline with a line.
Would be absolutley brilliant if we could "fill" it as well, but I dont think Xpression has a way to create a multi polygonal object (except a line).
Anyway, here's my troubled project at the moment... If I turn off the Spline Interpolation (at least one this version), it disappears completly.
Running XPR Designer v9.5 build 4978 (64-bit)
Link: https://www.dropbox.com/s/8qt6cu0lu78jbl7/LineObj.xpp?dl=0
Aleksander Stalsberg
Norway
Sent: 10-10-2022 11:48
1. when you trigger the line again do you want it to animate again or do nothing?
2. I actually don't know without looking at the project.
You can share your project with me if we wish and I can take a look, can't be sure I can fix anything but worth a look.
Sent: 10-10-2022 09:46
Hi there guys!
Thanks for this little forum post! Definetly helped me along on how to get some line graphs going.
@Simon Redmile I did run into two problems though...
- How did you stop the lines from looping back around the 0-point if trigged multiple times?
I kinda assume it's in there, as it was mentioned as a problem, but I just cant see where...
- If I turn off "Use Spline Interpolation" the line that is auto generated by the script disappears.
But if I add a point list manually it works just fine... Why? And how do I fix?
Norway
Sent: 07-25-2022 10:47
The most common reasons for preview not working is, preview script is broken or, something in your script is reliant on something in VL or perhaps a macro that's being set by data and it isn't being resolved when that single frame is rendered. Something that will be corrected when it plays online as it continues to render so if something isn't in order that issue is hidden.
Sent: 07-20-2022 16:56
Hey Red,
I've gotten back around to this---the script works beautifully.
Because of some extensive visual logic support, I did have to move the script to scene director events.
I found I needed this solution when I started building out the parts to make multiple lines and they stopped previewing in sequence mode.
I got all that ironed out yesterday and I had five lines working.
Today, I decided to add some text on color coded quads across the top describing what each line represented which included some fairly simple visual logic to size the quads to the text and position the groups containing quads/text.
Now, my previews in sequence mode have disappeared again.
Any idea what might cause this?
Thanks,
James.
Will have to rework the vertical scale, but I'm close!
James Hessler
WAAY (HEARTLAND MEDIA)
Sent: 07-08-2022 05:22
You could put an if statement in that checks if the values are zero.
if ptline.posx = 0 then
else
Lines1.AddPoint(ptLine1.PosX,ptLine1.PosY,0,Diameter.text)
end if
Sent: 07-07-2022 22:52
Hey Red,
I got the loop working, but still can't stop the loop depending upon how many of the quads are used to define the lines object.
I created a pointcount in visual logic and tried to insert that as the "to" integer, but wasn't successful in getting it to work.
dim Diameter,text1 as xpTextObjectdim Lines1 as xpLinesObjectdim Line1 as xpPointListdim ptLine1 as xpQuadObjectdim PointCount1 as xpTextObjectdim Count1 as xpQuadObjectdim i as integerself.GetObjectByName ("Diameter", Diameter)self.GetObjectByName ("PointCount1", PointCount1)self.GetObjectByName ("Count1", Count1)self.GetObjectByName ("Lines1", Lines1)self.GetObjectByName ("text1", text1)Lines1.SetCurrentList(0)for i = 1 to 4'for i = 1 to (CInt(PointCount1.text))Self.GetObjectByName("pt" & i & "Line1", ptline1)Lines1.AddPoint(ptLine1.PosX,ptLine1.PosY,0,Diameter.text)Next i
Can you tell what I'm doing wrong?
Thanks,
James.
James Hessler
Sent: 07-07-2022 06:02
You should definitely look at writing a loop for this.
for i = 0 to (hitPosX.length-1)
hitLinesObj.AddPoint(cdbl(hitPosX(i)), cdbl(hitPosY(i)), cdbl(hitPosZ(i)*-1), hitLineDiam)
next
This loop looks at hitposx which is a text string and looks for how many points there are in the string and runs the loop that many times only meaning it will stop when it runs out of points avoiding the zero.
However if I understand your project its multiple text boxes so you might want to right something like;
dim Diameter as xpTextObject
dim i as integer
for i = 0 to 12
Next
This will do the first line, you'll need to do more for rest.
Sent: 07-07-2022 00:23
Hey Red!
I couldn't be sure that BeginUpdate and EndUpdate were what I needed, but I patched up my syntax and got a single 3D line made with four points working.
I used my list that I had been working with in layout mode, but deleted all the points before I playing it out in sequence mode.
I have keyframed the percentage of the line visible on each of ten lines and want up to twelve points on each line---think deaths or cases by month---and plan to reveal one line at a time.
My problem now is that my script is creating linelist points from unused quads which I've defaulted to position (0,0,0), so all my lines loop back to zero---it is cool to watch, but not what I need.
I started playing with if-thens, but ten lines of twelve points was starting to hurt my head!
Any ideas?
Thanks,
James.
I truncated this script to set points only for the first line...
dim Diameter as xpTextObjectself.GetObjectByName ("Diameter", Diameter)dim Lines1, Lines2, Lines3, Lines4, Lines5, Lines6, Lines7, Lines8, Lines9, Lines10 as xpLinesObjectdim Line1, Line2, Line3, Line4, Line5, Line6, Line7, Line8, Line9, Line10 as xpPointListdim pt1Line1, pt2Line1, pt3Line1, pt4Line1, pt5Line1, pt6Line1, pt7Line1, pt8Line1, pt9Line1, pt10Line1, pt11Line1, pt12Line1 as xpQuadObjectdim pt1Line2, pt2Line2, pt3Line2, pt4Line2, pt5Line2, pt6Line2, pt7Line2, pt8Line2, pt9Line2, pt10Line2, pt11Line2, pt12Line2 as xpQuadObjectdim pt1Line3, pt2Line3, pt3Line3, pt4Line3, pt5Line3, pt6Line3, pt7Line3, pt8Line3, pt9Line3, pt10Line3, pt11Line3, pt12Line3 as xpQuadObjectdim pt1Line4, pt2Line4, pt3Line4, pt4Line4, pt5Line4, pt6Line4, pt7Line4, pt8Line4, pt9Line4, pt10Line4, pt11Line4, pt12Line4 as xpQuadObjectdim pt1Line5, pt2Line5, pt3Line5, pt4Line5, pt5Line5, pt6Line5, pt7Line5, pt8Line5, pt9Line5, pt10Line5, pt11Line5, pt12Line5 as xpQuadObjectdim pt1Line6, pt2Line6, pt3Line6, pt4Line6, pt5Line6, pt6Line6, pt7Line6, pt8Line6, pt9Line6, pt10Line6, pt11Line6, pt12Line6 as xpQuadObjectdim pt1Line7, pt2Line7, pt3Line7, pt4Line7, pt5Line7, pt6Line7, pt7Line7, pt8Line7, pt9Line7, pt10Line7, pt11Line7, pt12Line7 as xpQuadObjectdim pt1Line8, pt2Line8, pt3Line8, pt4Line8, pt5Line8, pt6Line8, pt7Line8, pt8Line8, pt9Line8, pt10Line8, pt11Line8, pt12Line8 as xpQuadObjectdim pt1Line9, pt2Line9, pt3Line9, pt4Line9, pt5Line9, pt6Line9, pt7Line9, pt8Line9, pt9Line9, pt10Line9, pt11Line9, pt12Line9 as xpQuadObjectdim pt1Line10, pt2Line10, pt3Line10, pt4Line10, pt5Line10, pt6Line10, pt7Line10, pt8Line10, pt9Line10, pt10Line10, pt11Line10, pt12Line10 as xpQuadObjectself.GetObjectByName ("Lines1", Lines1)self.GetObjectByName ("pt1Line1", pt1Line1)self.GetObjectByName ("pt2Line1", pt2Line1)self.GetObjectByName ("pt3Line1", pt3Line1)self.GetObjectByName ("pt4Line1", pt4Line1)self.GetObjectByName ("pt5Line1", pt5Line1)self.GetObjectByName ("pt6Line1", pt6Line1)self.GetObjectByName ("pt7Line1", pt7Line1)self.GetObjectByName ("pt8Line1", pt8Line1)self.GetObjectByName ("pt9Line1", pt9Line1)self.GetObjectByName ("pt10Line1", pt10Line1)self.GetObjectByName ("pt11Line1", pt11Line1)self.GetObjectByName ("pt12Line1", pt12Line1)Lines1.SetCurrentList(0)Lines1.BeginUpdate()Lines1.AddPoint(pt1Line1.PosX,pt1Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt2Line1.PosX,pt2Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt3Line1.PosX,pt3Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt4Line1.PosX,pt4Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt5Line1.PosX,pt5Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt6Line1.PosX,pt6Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt7Line1.PosX,pt7Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt8Line1.PosX,pt8Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt9Line1.PosX,pt9Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt10Line1.PosX,pt10Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt11Line1.PosX,pt11Line1.PosY,0,Diameter.text)Lines1.AddPoint(pt12Line1.PosX,pt12Line1.PosY,0,Diameter.text)Lines1.EndUpdate()
James Hessler
Sent: 07-06-2022 09:05
Hey James,
Rather than update you could try clearing the list adding a new list and then adding the points to that?
