We're getting a couple of Panasonic UE-150 cameras to add to our Panasonic CX350s, but I'll only have a day or two for setup before using them for the live podcast-style event they're being purchased for (starting this Friday). I will be using PTZ presets for each camera as tight shots for six guests, and would like to trigger these presets from our Acuity (not Dashboard). I know the RP60 controller accepts GPIO via DB25, but I have no experience setting this up.
For example, is it just a regular DB25 serial cable to connect the two, or something custom-made? Any protocol gotchas, or is GPIO standard between these two devices? I don't know how to configure the Acuity at that level, although I've set up plenty of attached custom controls, etc. Worst case is I can trigger the presets from the RP60 panel, but I'm trying to simplify for the operator.
We do NOT need to control the actual PTZs from Dashboard, just remotely trigger presets, so I shouldn't need the Panasonic protocol license (?)
Any guidance would be greatly appreciated.
Bryan Block
Malick Media
