Hello Les & Co.
I'm trying to send some commands from Carbonite to Caprica. In the device section I've added a generic device with Caprica IP. I used the port 7788 and set Roll Clip to Off. Then, in Custom Control I tried to run a simple CC targeting that Device, that should have run another CC in Caprica
I used first the menu "Devices/RossTalk (Generic)/CC" - it didn't work
Then I tried "Devices/RossTalk (Generic)/RossTalk Custom Command" and wrote in the text box "CC bank:cc" - it still didn't work
Do you have any clue about what I'm doing wrong? Do I use the wrong port?
Thank you,
Sorin
Sorin Podeanu
technical director
Euronews Romania
