  • 1.  Sequence not playing from the right position
    Posted 09-11-2022 11:53
    I am running a pair of sequences on an Ultrix Acuity that periodically will play opposite from each other. They are only being played thru a custom control, so I'm not sure why one would play from the beginning and on from the end.
    Robert Blank
    TRADERS POINT CHRISTIAN CHURCH
  • 2.  RE: Sequence not playing from the right position
    Posted 09-13-2022 17:08
    You might need to make sure that you have a pause between the load of the sequence and the Run that is sufficient to ensure that it's not being dropped and thus running from where it was previously..
