This is just a matter of programming style, but VB does have a switch/case option called select/case. The difference is it looks like it does not have "fall through". It can be more graceful and easier to read.
Sent: 11-22-2023 15:14
Subject: Setting font material without using tags
I figured out what was happening. At one point I had multiple layers, one for each selectable style, in the font's face thinking I would use the ".Enable" command. Removing the extra layers resolved the issue. My final script is below. Thank you everyone for your help!
dim txtStyle as xpTextObject
dim fontTitle as xpFont
dim fontStyle as xpFontLayerAttrib
dim matFont as xpMaterial
Self.Project.GetFontByName("FS Title", fontTitle)
Self.GetObjectByName("Style", txtStyle)
fontTitle.GetLayerAttribByName("Face", fontStyle)
fontStyle.GetMaterial(matFont)
If (txtStyle.Text = "Normal" OR txtStyle.Text = "Elections") Then
matFont.ColorDiffuse.Update(0,47,124,100)
Else If txtStyle.Text = "Breaking" Then
matFont.ColorDiffuse.Update(156,2,1,100)
Else If txtStyle.Text = "Sports" Then
matFont.ColorDiffuse.Update(80,94,101,100)
End If
John Robbins
Graham Media Group INC
Sent: 11-22-2023 09:59
could you just grab the font material by its name and then just adjust it like you would any other material?
Sent: 11-22-2023 09:57
Thank you. You're right in that I forgot to declare the material. However, upon further testing I found that the "Face" attribute does not seem to be setting the material. I can declare the other font attributes (border, neon, stroke, shadow) and see the color change as expected, but the "Face" attribute does not set. Update code below. Note ".Enabled" and ".Size" were used to test the other attributes to verify the code was working.
'fontStyle.Enabled = True
'fontStyle.Size = 50
End If
John Robbins
Sent: 11-22-2023 09:23
You are setting the ColorDiffuse on the fontLayer, not the material. Also, your material is not declared.
If (txtStyle.Text = "Blue" OR txtStyle.Text = "Elections") Then
Else If txtStyle.Text = "Red" Then
End If
Use Self.Project instead of Engine because Engine can affect materials from one Scene to another.
Fingers crossed.
Azathoth
Son of Cthulhu
Sent: 11-22-2023 09:03
Thank you for the suggestion. I tried that with no luck.
John Robbins
Sent: 11-20-2023 12:01
Instead of using "Engine.GetFontByName" try using "Self.Project.GetFontByName".
If that change works, I cannot explain why it does; it just does. It fixed a problem when I was making materials.
Azathoth
Son of Cthulhu
