No is the easy answer. - I mean if you can navigate to the file in a windows explorer window on the production truck, then sure you can link to it. ---- for any solution provided, doing data over wifi could always be tricky.
The cleaner step would probably be to instal datalinq on the computer that has the excel sheet, and then point your production truck computer to that IP address in xpression datalinq manager. - I would also make sure if still using wifi to make sure you use static IP addresses and not DHCP.
Would still just be an ADODB because it is an excel sheet.
Garrett Hall
Overtime Elite
Atlanta United States
