I think it is more so a safe guard against the mass users. Because if you had the same take item in 2 xmls, then the software would not know what to do with the 2nd. - the software can read if a take item is taken from a single xml load, but xml files just carry such little data to them.
Garrett Hall
Overtime Elite
Atlanta United States
Sent: 06-29-2025 13:36
Subject: Shift Click on XML Import Window
This is definitely a feature that needs to be added. Multiple pieces of an XML is a painful workflow to manage on the file side, plus it is still the same issue if we are pulling graphics out of an XML from another game/site.
Jack Reynolds
Sent: 06-29-2025 13:32
No. - But I would just suggest saving off the items you need into the 1 xml. - When I used to do ESPN shows, I was usually doing 3-5 xml loads per xpression machine to get all the pieces that I needed for a show.
Garrett Hall
Overtime Elite
