Sent: 04-06-2026 11:00
Subject: Shuffle Play A Take Item Group In Xpression
Hey Zachary,
Thank you for the help. It seems that my version of Xpression doesn't have access to "takeItem.Index" or "MoveTakeItemByIndex". I can kind of get around the first one with "takeItem.UserData", but I don't have access to any move methods for Engine.Sequencer.
I'm operating on Xpression Studio v10.55 build 1002.
[Nick] [Kubinski]
[Studio Production Specialist]
[Sysmex America Inc.]
[Vernon Hills] [USA]
Sent: 04-03-2026 12:45
Hey Nick!
I wrote this earlier for someone else, this should work for what you want to do. Place this in a Keyboard Shortcut script, select the group you'd like to randomize:
dim tig as xpTakeItemGroupIf Engine.Sequencer.GetFocusedTakeItem(tig) Then dim itemCount as integer = tig.ItemCount dim bottomIndex, topIndex as integer dim firstItem, lastItem as xpTakeItem tig.GetFirstTakeItem(firstItem) tig.GetLastTakeItem(lastItem) bottomIndex = firstItem.Index topIndex = lastItem.Index Randomize() dim groupID as integer = tig.ID dim firstID as integer = groupID + 1 dim lastID as integer = groupID + itemCount dim tiFirst, tiLast as xpTakeItem Engine.Sequencer.GetTakeItemByID(firstID, tiFirst) If Not Engine.Sequencer.GetTakeItemByID(lastID, tiLast) Then MsgBox("Unable to find final expected ID; have you renumbered (Ctrl+R) the entire list to make items sequentially numbered?") return End If dim message as string = "Randomizing from " + vbCrLf + CStr(firstID) + ": " + tiFirst.Name + vbCrLf + "to" + vbCrLf + CStr(lastID) + ": " + tiLast.Name + vbCrLf + vbCrLf + "Does that sound right?" dim response = MsgBox(message, vbYesNo, "Randomizing Items") If response = vbYes Then For i as integer = 0 to itemCount - 1 dim ti as xpTakeItem Engine.Sequencer.GetTakeItemByID(groupID + 1 + i, ti) dim futureNum as integer = CInt(Math.Floor((topIndex - bottomIndex + 1) * Rnd())) + bottomIndex Engine.Sequencer.MoveTakeItemByIndex(ti, futureNum) Next End IfEnd If
Zachary Fradette
United States
Sent: 04-02-2026 13:55
So I think I found a work around. I can reassign the take IDs with new random values and the operator can sort everything by Take ID and run the group as normal.
dim takeItem1, takeItem2, takeItem3, takeItem4, takeItem5, takeItem6, takeItem7, takeItem8, takeItem9, takeItem10 as xpTakeItemdim randVal1, randVal2, randVal3, randVal4, randVal5, randVal6, randVal7, randVal8, randVal9, randVal10 as Integerdim takeID1, takeID2, takeID3, takeID4, takeID5, takeID6, takeID7, takeID8, takeID9, takeID10 as Integerengine.Sequencer.GetTakeItemByID(62, takeItem1)engine.Sequencer.GetTakeItemByID(63, takeItem2)engine.Sequencer.GetTakeItemByID(64, takeItem3)engine.Sequencer.GetTakeItemByID(65, takeItem4)engine.Sequencer.GetTakeItemByID(66, takeItem5)engine.Sequencer.GetTakeItemByID(67, takeItem6)engine.Sequencer.GetTakeItemByID(68, takeItem7)engine.Sequencer.GetTakeItemByID(69, takeItem8)engine.Sequencer.GetTakeItemByID(70, takeItem9)engine.Sequencer.GetTakeItemByID(71, takeItem10)randVal1 = Int((10 * Rnd) + 1)randVal2 = Int((10 * Rnd) + 1)randVal3 = Int((10 * Rnd) + 1)randVal4 = Int((10 * Rnd) + 1)randVal5 = Int((10 * Rnd) + 1)randVal6 = Int((10 * Rnd) + 1)randVal7 = Int((10 * Rnd) + 1)randVal8 = Int((10 * Rnd) + 1)randVal9 = Int((10 * Rnd) + 1)randVal10 = Int((10 * Rnd) + 1)takeID1 = 61 + randVal1takeID2 = 61 + randVal2takeID3 = 61 + randVal3takeID4 = 61 + randVal4takeID5 = 61 + randVal5takeID6 = 61 + randVal6takeID7 = 61 + randVal7takeID8 = 61 + randVal8takeID9 = 61 + randVal9takeID10 = 61 + randVal10takeItem1.ID = takeID1takeItem2.ID = takeID2takeItem3.ID = takeID3takeItem4.ID = takeID4takeItem5.ID = takeID5takeItem6.ID = takeID6takeItem7.ID = takeID7takeItem8.ID = takeID8takeItem9.ID = takeID9takeItem10.ID = takeID10
[Nick] [Kubinski]
Sent: 04-01-2026 13:26
Hi Juha,
Unfortunately the take items are all different durations so that wouldn't work for us.
[Nick] [Kubinski]
Sent: 03-31-2026 16:59
Hi Nick,
If your randomly repeated take items are all the same duration, you can create a second group where you place that scene, which triggers the random start, twice. Then set that group to be timed with whatever interval you want, and configure it to repeat when done."
Juha Koivisto
Tampere
Finland
Sent: 03-31-2026 13:23
I was able to get the script to work with the existing take IDs! I had 2 issues, (1) I was activating the group which overrode the scene's script, and (2) I was changing the values in ((10 * rnd) + 1) to the exact take IDs I wanted to play.
I'm still trying to figure out how to get the other take items in the group to play after the first one is chosen at random.
dim takeItem1 as xpTakeItemdim randVal as Integerdim takeID as IntegerrandVal = Int((10 * Rnd) + 1)takeID = 61 + randValengine.Sequencer.GetTakeItemByID(takeID, takeItem1)If Not takeItem1 Is Nothing Then takeItem1.Execute()End If
[Nick] [Kubinski]
Sent: 03-26-2026 13:32
base take id number
Sent: 03-26-2026 13:11
I'm also trying something like this but for videos playing randomly giving the impression an animation guy is talking. Do you have the change the play out mode of the group? Also when I compile the code it come back good but does nothing when taken online other than play the one scene.
Idk what value to put here
Base 1000 + random - <--change this to your value-->
i just put a 8 as that's the amount of scenes I have?
if you could also help me out I'd appreciate sorry for the ignorance.
Adam Reese
Sent: 03-18-2026 17:19
yeah what you could do is have a dummy scene that you always take online i.e 1000 and then inside that scene onOnline have this script.
Dim takeItem1 As xpTakeItem
Dim randVal As Integer
Dim takeID As Integer
' Random 1–10 <-- change this to the random range you want-->
' Base 1000 + random - <--change this to your value-->
takeID = 1000 + randVal
' Get the take item by ID
' Execute it
takeItem1.Execute()
End If
if you don't want the same item to accidently play twice you could add a script to disable that item on offline.
