Hi all,
Maybe I am just overlooking something really stupid and simple, but for the life of me I can't seem to get this to work:
var name = params.getValue('HomeLT_Name_1', 0);
var length = params.getValue('Home_Roster_NumberOfPlayers', 0);
ogscript.debug("NAME IS " + name);
for (var i = 0; i <= length; i++)
var tableName = params.getValue('homeRoster.' + i + '.name',0);
ogscript.debug("COMPARING: " + name + "/" + tableName);
if (name.equals(tableName))
ogscript.debug("NAME FOUND: " + name + " = " + tableName);
else
ogscript.debug("NOT A MATCH");
I can see in the debug it does compare the right elements, and I can see the instance in which variables "name" and "tableName" match, but the if statement seems to not see it and I see "NOT A MATCH" for every comparison.
I have also tried "if (name == tableName)" instead of "if (name.equals(tableName))" but it is the same result with no matches found.
Sorry if it is an easy solution, but I can't see what is wrong here, especially since I can see the instance in the debug code where the if statement should logically be true.
Jake Lew
Access Communications Co-Operative Limited
