yeah you can go to sequence and change group settings from manual to timed.
Sent: 08-30-2023 14:40
Subject: Stagger Animation on imported PSD File
My first stagger animation exercise was with a rasterized logo that also includes text. That's where I stumbled upon the issue. I then used the simple text only for error searching and demonstration purposes, so that I don't post anything that violates copyright or similar issues.
Now that I've found a simple workaround, the question is basically resolved for me. Thanks for the support.
P.S. Quick question in between: Is there a way to play a group in sequence (F4) as a 'playlist'? If Take item 1 is taken offline then take item 2 starts automatically?
Phil Benthien
Sent: 08-30-2023 13:43
I always recreate text inside XPression and just use the PSD for the shapes, background, and and placement reference.
I usually eye-match the text as close as possible so that it is dynamic inside XPression.
Since I do that stagger acts as usual, probably why I haven't come across this but pivot position interpretation would make sense with the images.
Is there a reason you don't want to be able to change the text live?
Sent: 08-30-2023 12:53
Yes, the layers are rasterized, and some parameters work smoothly, but not all of them. After trying various things, I believe the issue lies in how XPression interprets the position data and the pivot of a PSD file. I'll attach a short video again, in which this can be observed. Or does this just happen on my side? The quickest workaround I found is also demonstrated in the video.
Phil Benthien
Sent: 08-30-2023 10:06
I tried on a psd of my own and it appears to work.
Are those layers rasterised in your PSD?
Sent: 08-30-2023 09:20
Cool. Then I will add this video here. During the first playback, the animation is on a text field. During the second run, I used the textures imported through the PSD and placed them manually on self-created quads. During the final run, you can see the imported PSD. Quads are created automatically and the textures are applied. The effect does not work here.
Phil Benthien
