Today I'm on other pc and on version 11.0 and it opens. Thank you!
Sent: 01-07-2025 09:24
Subject: Stagger Animations & Pivot Points
Are you able to open the xpf?
Sent: 01-07-2025 04:52
Hi Simon,
I have almost the exact goal as Jordan, to animate h spacing but I don't even need it to have middle pivot. However I'm struggling to import your xpfs. I'm on 10.5 build 5508 - can it be a version issue?
Juha L
Designer
Sent: 06-24-2024 10:24
No worries, pleased it works!
Sent: 06-24-2024 08:16
Hi Simon,
This works perfectly. I really appreciate your help with this.
Jordan
Jordan Allen - Mix Effect Media XPression
London United Kingdom
Sent: 06-24-2024 06:40
Because "OnRender" can be demanding I also made this version that uses "OnSetText" instead and then used a format float to reduce the decimal places so it doesn't update as often, you could use this to control how smooth the animation is as well which is pretty cool.
Sent: 06-24-2024 06:27
Hey Jordan,
I was intrigued by your request so I had a little play and made the project attached.
It animates the font scaling directly so you'll need a specific font for each item you want to animate individually.
Also be aware its using "OnRender", I would test any scene using this quite a bit.
Sent: 06-24-2024 02:30
Unfortunately you can't animate HSpacing in the animation controllers/scene directors as that is not an option that comes up when setting your keyframes.
Jordan
Sent: 06-24-2024 01:03
You can't do it in Stagger Animations, you need to animate H Spacing in Scene Director.
Gabriel Rosca
Bucharest, Romania
