I have an Incoder which is running two different Datalinq Servers, both on different ports.
One Datalinq is handling local data sources, while the other is handling online data sources.
This way, if the online sources are not available, the local data still gets updated. If you put them on the same datalinq while the online sources are not available, the local data might not get updated either due to the many error-messages of the offline datasources.
Ideally, I would like both Datalinq Servers to boot with Windows but to have them linked to their respective ports.
However, trying to define the port in the startup-path doesn't work. (So "C:\...\datalinqserver.exe" -port=8890 doesn't work)
Is there any way to have different Datalinq Servers boot with different ports?
Kenneth Buck
Senior Graphics Developer
Bold Graphics
Belgium
