  • 1.  "Export Take Item To -> Video" rendering from the Sequencer error?
    Posted 08-06-2022 06:32
    When I want to render out a 2min countdown widget from within the sequencer option "Export Take Item To" -> "Video", the clock in the rendered-out video is running at half speed.
    The Hardware Video Mode is (from project) HD 1920x1080i 25fps.
    The settings in the Export window:
    I've also tried it with the frame mode set to "Frame Based", but results in the same half speed.
    Rob van Rooyen
    Senior Graphics Specialis
    NEP The Netherlands
    Hilversum Netherlands
  • 2.  RE: "Export Take Item To -> Video" rendering from the Sequencer error?
    Posted 08-09-2022 08:44
    Having qualified software testers on your team is vital for the development of reliable, bug-free software. As an experienced tester, you can help ensure that a product is bug-free and secure https://mlsdev.com/blog/hire-a-development-team. Fortunately, software testing is an extremely rewarding field. If you'd like to join this growing industry, there are a few things you should know before you get started. Here are a few of the benefits of having testers on your team.
    Nick Miles
    Engineer
    naza
  • 3.  RE: "Export Take Item To -> Video" rendering from the Sequencer error?
    Posted 08-15-2022 10:29
    Hello Rob.
    This is normal - the "Export Item To" feature renders the video in non-real time. The countdown works using the system time. And the result is that your countdown has half speed. For that better creat the countdown in AE.
    ROMAN YAROSHENKO
  • 4.  RE: "Export Take Item To -> Video" rendering from the Sequencer error?
    Posted 08-16-2022 05:28
    ahhh... that makes sense... Next time I will have to build a clock that runs by an animation via scene director I guess.
    Rob van Rooyen
    NEP The Netherlands
  • 5.  RE: "Export Take Item To -> Video" rendering from the Sequencer error?
    Posted 08-16-2022 10:36
    We'll investigate if this is considered a bug in XPression or not.
