  • 1.  Stream Deck and xPression
    Posted 09-01-2022 15:40
    Hi!
    Is there a way to disable that taking items on air from the stream deck opens the page in preview?
    Chris Nicolay Wernersen
  • 2.  RE: Stream Deck and xPression
    Posted 09-06-2022 10:05
    Which Streamdeck command are you using?
  • 3.  RE: Stream Deck and xPression
    Posted 09-07-2022 03:26
    Hi!
    I'm using Stream Deck with the Companion app. I'm using SEQI-commands.
  • 4.  RE: Stream Deck and xPression
    Posted 09-07-2022 07:46
    SEQ commands both move the focus of the sequencer and trigger the take item. Switching to the TAKE command will trigger the take item, but not move the focus bar. The focus bar movement is triggering your preview.
  • 5.  RE: Stream Deck and xPression
    Posted 09-07-2022 14:08
    Ok, thanks! :)
